Gasoline Particulate Filters now coming on vehicles in the US
All while China dumps 1000X the garbage into the air and ocean.
When the Chinese installed that big screen to show the sunset in Beijing bcs. it was not visible anymore due to pollution; things dramatically changed there.
But I am amused by these discussions. I always have a few students who will in any topic argue how the US does best. It does not matter what the topic is, the US always does the best.
However, when something like this is a topic, they always say: well, what about Venezuela, Nigeria, etc?
It is like well, they are breathing bad air; why can't we?
GPF is a particulate device. It makes the air cleaner in your garage, neighborhood, etc.
It is not a complicated device. It does require low-SPAS oils, which the average American has been using for a long time without knowing it.
I thought some people here maybe interested in this information, so I put together my thoughts and my understanding of GPFs into this post.
TLDR: Increasing criteria pollution regulation (NOx, NMOG, CO, PM) are driving the need to add particulate filters to the exhaust after-treatment systems. Increased complexity may cause some reliability issues but overall should be more reliable than the diesel equivalent. Adding particulate filters will lead to cleaner air and healthier humans. It will also have an impact on the motor oil specification that manufactures will use. It will increase the number of manufacturers requiring low-SAPs oils.
As some of you may know, gasoline particulate filters have been around in Europe for a few years now and the diesel equivalent (diesel particulate filter or DPF) have been on diesel’s in the United States since the 2007 model year. But it looks like GPFs are now starting to show up on mainstream gasoline vehicles in the United States. For the 2025 model year BMW and Volkswagen have included GPFs on some of their vehicles. BMW has done it on their X3 and 3 series with the B48 and B58 engines. Volkswagen has added it on their Taos with the 1.5L EA211 engine.
View attachment 251633View attachment 251634
1732633062720-webp.251629
For those that don’t know, a GPF (gasoline particulate filter) is a type of substrate that goes in an exhaust system to filter out soot particles. It does that by forcing the exhaust through the porous wall of a substrate. By forcing the exhaust through the wall of the substrate, it filters out most of the soot the engine creates during combustion. Substrate manufactures can play around with the porosity of the particulate filters to optimize filtering ability and back pressure. These substrates are also typically coated with a washcoat similar to or the same as a TWC (Three-way catalyst) found on every gasoline vehicle now.
Since a GPF is a filter, it does need to be periodically cleaned through a process known as regeneration. The regeneration process works by oxidizing the soot particles that the GPF captures into CO2. The regeneration process will be slightly different on a gasoline engine compared to a diesel engine with a DPF. Gasoline engines produce significantly less soot than a diesel, so the soot loading will be significantly less and need to regenerate and clean out the particulates will also be reduced or depending on driving habits could be completely unnecessary. The soot oxidation process occurs at exhaust temperatures above 600C, which is very common on gasoline engines depending on placement of the catalysts and driving conditions. Since gasoline engines have higher exhaust temperatures but little to no available oxygen in the exhaust stream, most of the soot oxidation will occur passively during fuel cutoff deceleration. Since no combustion will be occurring, oxygen becomes available in the exhaust stream and when the temperature is above 600C, oxidation of the soot occurs. Although I’m sure the engine calibrations will have a defined active GPF regeneration strategy like on diesel engines, I imagine it only being used if someone granny cycles the car in extremely cold weather. The OEMs will also need to limit the use of active regeneration on gasoline engines because, in theory, that would increase the amount of NOx emissions. The reduction of NOx emissions by a TWC requires a rich A/F ratio so when the engine is running lean to oxidize the soot in the GPF, there will be an increase in NOx emissions.
On a diesel, they have to manually raise the exhaust temperature to the 600C target by injecting extra fuel into the exhaust so it is available to be oxidized, i.e. create heat, by the diesel oxidation catalyst that is placed in front of the DPF. Then since diesel’s run lean, the increased heat will burn the soot out over the course of the regeneration.
The addition of GPF will also have an impact on motor oils. Manufactures will start to require low-SAPs oil to protect the GPF from getting clogged early. The reason for that is, sulfated ash, phosphorus, and sulfur get captured by the filter and are unable to be burned out. Unlike soot which can be burned out, SAPS just get stuck in the particulate filter. Although, as long as the OEMs control oil consumption and size the GPF appropriately, a clogged GPF from low-SAPS oils shouldn’t be a problem.
Pros and Cons of particulate filters.
The major pro of them are less ultra fine (PM2.5) will be getting released into the air. PM2.5 is able to penetrate deep in lungs and cause damage to lung and cardiovascular system. PM2.5 is also known to increase the number of people with asthma and asthma attacks. It is also known to be a contributing factor in lung cancer too. So overall, a reduction in PM2.5 emissions is a good thing for overall health. Some testing the NIH (National Institutes of Health) did on a 2011 Ford F-150 with the 3.5 ecoboost showed between 85%-99% reduction in particulate matter emissions depending on the certification drive cycle. (FTP75, HWFET, US06)
The major con of having a GPF is the increased complexity, so there is a possible reduction in reliability.
So I see GPFs as a mixed bag of pros and cons. Hope you found this informative and interesting.
It's interesting as from my understanding all BMW suvs are built in Spartanburg then shipped to their respective markets. Is there something looming on the horizon for USA regulations that the public is unaware of? I haven't seen any specific data showing a gasoline engine with and without the soot filter. Third it's been mentioned here that direct injection causes more soot which seems odd as It's much more efficient and in theory should produce less particulates.
That is a false strawman. What percentage of particulate in the air today is because of modern vehicles, and what is the expense of these relative to the benefit - ie what is the ROI.
No one cares about the ROI because the bill goes to someone else. As mentioned above, squeezing the last 5% of efficiency out of any process is almost never worth it, but they don't care because their not required to show a ROI like those of us in the real world.
The money would likely be better spent elsewhere, to have a larger net befit to the environment and society.
So there now worried about a tiny bit of particulate in the air, but when I go to the grocery store a glass jar is seldom to be found. Plastic or poor metal that ends up in the landfill and leaches into everything else.
Follow the money / lobby - figure out who benefits from a particulate filter, and you will have your answer.
We the problem with DI was start up and low speed emissions. The plastic issues is more difficult to solve but just because we haven't heard of a solution doesn't mean people aren't working on it.
It's cold start and low speed where DI generates more pm2.5 emissions. This is partly why companies are using a dual PFI/DI systems where PFI is active at cold start and low speeds. If you want data I'm sure it's available from European sources because they've been using OPF for a few years now.
BMW just started employing the dual injection system earlier this year.
I agree with that. ROI in this case is questionable.
But also these comparisons between the US and whoever is at best, amateurish.
As for particulates, IMO, a $10,000 fine on diesel bros who take out DPF and jack up injection would do more for air than GPF.
Of course people care about the ROI. The ROI is found in reduced respiratory and heart related hospitalizations.
The fine right now is somewhere in the $4k range. We just need someone to enforce the already existing laws. (Seems like I've read this a time or two.)
Apparently New Delhi is so bad now that the smog and particulates are 77 Times higher than allowed by the WHO. That is insane. Part of this is that India allowed 2 stroke tuk-tuks for years and relies heavily on coal. I doubt that they require exhaust scrubbers
The video is eye searing (quite literally).
New Delhi choking on smog
To be fair part of the problem is that India and alot of African countries continue to use extremely old as in 60s and 70s diesel commercial vehicles for construction. These pollute 100's of times more than anything currently made. India would have been an ideal market for the Elio. Very low emissions and cheap to run. The 2-stroke tuk-tuks don't help either.
True, but we have a lot of low hanging fruit around to resolve before jacking up car prices even further.
The problem with prices is that reaction to it might do more damage to the environment. It is like a ban on ICE in 2035 in Europe. I said few years back here it won't happen, and it won't, bcs. those who campaigned for the ban were voted out, and those who did not lose seats in the EU Parliament are now afraid for their seats. The real problem is that people generally don't choose center parties, they go immediately for the jugular, and in the EU, you might see serious issues bcs. bans like that.
The real problem is the form of government. India is democracy, and as Churchill said, democracy is the most inefficient, chaotic form of government, but until we figure out a better one, we are stuck with it."
India is victim of democratic inefficiency and populism. China is a totalitarian regime, and the advantage of those (few advantages) is efficiency when pushing some changes. CCP can push changes super fast without worrying whether they will lose elections. In India? Try to ban those vehicles and see what happens. And it is not only vehicles, but using coal to cook, heat, burning trash, etc.
Don't get me wrong, I am not advocating for India to become a totalitarian regime, but totalitarian regimes are far quicker implementing changes, well, for a reason.
Who is mandating this additional equipment? If it is the EPA, it is more evidence that they need to have their wings clipped. These systems will no doubt add significant cost when they wear out, for gains that are probably small and incremental at best.
You know, it's interesting. If you pull up a chart of Eurozone GDP v. US GDP say around 2010 or so, the GDP output is almost the same. Today, roughly 15 years later, US GDP is about 40 percent larger. It is my contention that it is all of this climate and environmental insanity - it's become its own religion - that is contributing to significant inflation (mostly regulatory inflation) and restraining growth, particularly in the Eurozone, as power and energy have become very expensive. I am generally in favor of environmental protection, but this climate insanity needs to stop. And it we import the Euro approach into the US, we will be inviting the same economic stagnation.
No one is mandating the additionally equipment. The EPA and CARB set the standards and the OEMs can choose their path to meet the standards.
While I don't think I agree with all the EPA's MY27 emissions standards, I do think pushing manufacturers to produce cleaner cars over time is good. I believe the main driver of the needing the GPF is the FTP75 drive cycle that is will be done at -7C with the requirement of 0.5mg/mile of particulate matter. I think it should have been 0.5mg/mile for the regular FTP75 done at 20C and the -7C one should have been 1.0mg/mile. I know cars currently can meet the 0.5mg/mile PM standard without the GPF, but make it more challenging by adding -7C but have a looser standard. That way, it gives them more leeway to the manufactures but still controlling PM.
