Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 3,564
I have a 2000 Toyota Rav4 (160k miles, seems to have been abused and neglected mechnically) with a pretty significant oil leak from the timing chain covered which appears to have been replaced in 2007. I'm going to try 2 bottles of LM Motor Oil Saver to see if it can stop or slow down the leak. I am not sure if RTV was used and if LM works on those types of seals. I would like to try Viscoplus as well to see if it can reduce oil consumption.
Is it OK to mix the 2 products?
Viscoplus:
Mono functional additive that stabilizes motor oil viscosity. Provides outstanding protection against mechanical and permanent shear losses in extreme conditions and prevents viscosity loss caused by frequent cold starts.
Motor Oil Saver:
Maintains and regenerates rubber and plastic seals in the engine oil circuit of gas and diesel engines. Oil consumption due to aged and hardened valve stem seals is reduced. No more blue exhaust smoke, improved emissions. External leaks are minimized or even eliminated. Dampens engine noise and reduces repair costs. Reduces pollution and improves the environment.
Use in 4-stroke gas and diesel engines, with or without turbochargers. Miscible with most commercially available motor oils. Safe for use with catalytic converters and particulate filters (GPF/DPF). Not suitable for use with wet clutches! Contents (300 ml) is sufficient for 3–5 Liters (0.7 gal. to 1.1 gal.) motor oil. The product can be added at any time, sealing first takes effect after about 600-800 km (400-500 miles).
Viscoplus:
- optimum lubrication under all operating conditions
- optimum oil pressure under all operating conditions
- reduces oil consumption
- reduces engine noise
- minimizes viscosity loss
Motor Oil Saver:
- reduce engine noise
- maintains and regenerates rubber and plastic seals
- prevents oil leaks and pollution of the environment
- prevents blue exhaust smoke
