G96 CLP ?
PNW
I've been curious about the aboveG96 mil spec CLP oil in the 4oz. bottle - has anyone used before and if so what is your opinion ?
They make two different gun oils. The synthetic Gun Oil CLP one is approved for military use in the USA (MIL-PRF-63460E). (As of a year or so ago, it is/was the ONLY commercially available lube on the market available to consumers that meets MIL-PRF-63460E. There may be other lubes that are certified to meet that at this point, but I'm not sure. And there is a difference between a manufacturer saying it meets specs and a manufacturer that has actually been through the testing and become certified) Make sure to buy the synthetic one. I have used the synthetic one and honestly feel that if you want to buy/use only one product, than this is it. The stuff is fantastic. I own about 20 gun oils, and this stuff is my absolute favorite for most guns. I do prefer a thicker lube on AR platform rifles.
Regular CLP
Synthetic Gun Oil CLP
They also make this stuff which I find to be a decent enough cleaner and rust preventer, but not that great of a lube (and hard to apply if using as a lube).
+1 - I have used this one as well on my pistols and bolt rifles and it works well.
Originally Posted By: 901Memphis
Mil spec requirements are low for CLP, only requiring 70% on the first pass clean. Mpro7 LPX does 98% first pass
And? Its not certified. If it could pass the test, then they would submit it as such, and get it fully certified. The military contracts are HUGE and that is where the lube companies like to make their bread and butter money.
Bubba... Your G96 synthetic pic shown here is not a CLP. It's a LP.
Currently my (2) CLPs are Lucas Extreme Duty and Slip 2000EWL. I use old-school Ballistol CLP on all my gun exteriors.
Your first pic is not a CLP. As for that 2nd pic, I've never seen that bottle before. Is it exclusive for military, or do places like Bass Pro Shop sell it?
What are you talking about? Repeating the same non-sense again, does not make it correct the second time. The product is called "Synthetic CLP Gun Oil" right on their web page.
http://www.g96.com/products/synthetic-clp-gun-oil/
Its there 0.5 ounce bottle. Its available in the military supply line and over the counter.
I am in the camp that after 15 years on Bitog...no one is yet to p[rove that one oil is better than another in terms of performance. Yes a quality syn may go a bit longer. But I am willing to bet that in 150K miles..changing the oil every 6K miles the engine longevity is not a function of the brand.
Probably the brand and type of gun oil is not different except maybe in a highly used AR.
Clean and lube the firearm every 500 rounds and it will look the same no matter what oil you use. I would buy this oil bc it suckered me in. Which I may do..lol.
Here's the military test spec (MIL-PRF-63460E) for CLP type products.
http://g96.com/docs/MIL-PRF-63460E_AMENDMENT-2.pdf
6.1 Intended Use.
CLP covered by this specification is a highly penetrating, mobile liquid and is intended for field application to satisfy the complete need of cleaning, lubricating, and short term preservation of military weapons. CLP facilitates the effective removal of firing residues, gums and other contaminants from weapon components while providing lubrication and short term preservation for reliable weapons operation.
Originally Posted By: ZeeOSix
Not everyone thinks CLP products are the best way to go about gun care...
They're not. All CLP was designed for was to be a, "one product cure all" for the military. There is no reason for a civilian gun owner to use only one product for maintaining firearms. In fact, it's silly. Why would you limit yourself to using the same product to remove barrel fouling, as you would to lubricate slide rails or bolt lugs?
I've used the G96 (spray can treatment) once brush cleaning slides. I still wipe and oil afterwards.
Currently its Bore Tech carbon and Bore Tech copper (out of Bore Tech Eliminator) - and either Weapon Shield oil or EWL Slip 2000 oil. I've tend to use the CLPs now for other things around the home.
I'd be willing to give the G96 LP a try as I use other products for cleaning . Not sure the G96 would be better than their CLP but should be better as a lube ?
They sell two gun oils. Both of them are CLP oils.
1) synthetic CLP gun oil (meets military specs)
2) non-synthetic CLP gun oil (which is identical to their G96 Gun Treatment aerosol spray)
I'm not sure what this sentence means, as it is an incomplete thought.
Here is an identical sentence structure, using McDonald's and their sandwiches in comparison.
"Not sure the McDonald's would be better than their double cheeseburger but should be better as a sandwich?
My problem with G96 is their labeling. Everything they sell is a CLP. Or so it is stated on the can or bottle. It's not a "Gun Oil", a "Synthetic Gun Oil", or a "Gun Treatment". That is confusing the product. If it's a CLP, then that's what it is, and what it should be sold as. Nothing else they put on the label will take it out of that category. I should also mention that G96 is not the only one out there doing this.
No, it's not there in YOUR pic (post #456812). That not a CLP. If it were, then the wording would lead with Clean - then Lube - then Protect.
Because it says clean-up, that's deceiving and nowhere is that pic marked as CLP.
So stop YOUR nonsense. I haven't typed any nonsense. Get a pair of eye glasses perhaps.
