Yes, Mobil1Which synthetic grease?
There’s so many choices, do you mean the Mobil One synthetic grease?
I use BreakFree; Clenzoil; Amsoil & Ballistol. I’ve considered Avid gun care products, not bought any yet.So far , no one is looking to try anything new .
There is a YouRube video called Sirache Lube (or something similar) of a guy who mixed M1 motor oil with Mobil Synthetic Grease until like a honey like consistency for firearms.For the past year or so I have been using a mix of Mobil1 10w30 and Synthetic grease. I mix it just thick enough that it doesn't run off.
It's almost a gel. It's been great so far. It has very good lubricating properties, and cleaning my guns after a range trip has been a breeze.
I got the idea from a School Of The American Rifle video.There is a YouRube video called Sirache Lube (or something similar) of a guy who mixed M1 motor oil with Mobil Synthetic Grease until like a honey like consistency for firearms.
The knock on Frog Lube and why it’s popularity plummeted is the same reason as most plant based lubes : They become gummy / tacky / sticky with age after application while in storage .Skip the Frog Lube. The retired SEALs I know (one of whom builds guns, and is an FFL for a living) say to stay away from it. That’s all the endorsement I need.
What ever CLP you use is probably better and longer lasting than REM Oil which is thin and evaporates quickly . For a low cost investment - buy Lucas Extreme Firearms Oil in place of using REM Oil . The only place I use REM Oil any more is to spray a new semi - auto recoil spring assembly with it (gunsmith trick) to slicken it up for the first few hundred rounds ensuring better reliability. Rails , barrels , connectors , etc. all get a thicker oil than REM Oil.I have been using CLP for cleaning but use Remmington gun oil for lubrication. Seems to work out fine.
Thanks. I'll get some of the Lucas Extreme.What ever CLP you use is probably better and longer lasting than REM Oil which is thin and evaporates quickly . For a low cost investment - buy Lucas Extreme Firearms Oil in place of using REM Oil . The only place I use REM Oil any more is to spray a new semi - auto recoil spring assembly with it (gunsmith trick) to slicken it up for the first few hundred rounds ensuring better reliability. Rails , barrels , connectors , etc. all get a thicker oil than REM Oil.
The Hoppes #9 lubericating oil would be fine as well (thicker lube than REM oil with less evaporation) .Thanks. I'll get some of the Lucas Extreme.
I have some of this also, haven't even opened it yet. You ever tried this? Hoppes #9 Lubricating oil
https://www.amazon.com/gp/product/B0013R67A6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Wow! That was our PPS. Here was the PDS for it:Well looky what I found. Knew I had some left.
Formulated and made by our very own @MolaKule. Best dang stuff for full rail and slide frame guns with dissimilar metals like older Sigs. Also could clean like the dickens when other stuff had problems. Really wish I had more *wink *wink.
