Do these fumoto valves stand up to hot/cold climates in the long term?Since the body is made of brass would cold weather split the valves body?I have one and I’m ready to install but a few concerns I have.Thanks
As someone who knows Star Wars freaks I must say that that is not a "yoda outlook".but I blamed the valve when I had the reach around at odd angles to get to the zerks
Alternatives if you're not comfortable with the Fumoto design.Do these fumoto valves stand up to hot/cold climates in the long term?Since the body is made of brass would cold weather split the valves body?I have one and I’m ready to install but a few concerns I have.Thanks
I've been considering the Valvomax for my WRX. Maybe today is the day I place an order....You may want to check the Valvomax and Stahlbus out also.
The Valvomax style is the best for Subaru, the Fumoto hangs down and is in dangerous spot.I've been considering the Valvomax for my WRX. Maybe today is the day I place an order....
The drain plug on that car is, I think, made out of pot metal! It already looks like it'd been removed and replaced about a thousand times.
This is a good point. The location of the valve was beside the oil pan on my F150. I’d have some serious reservations about running one that hung down below the pan.The Valvomax style is the best for Subaru, the Fumoto hangs down and is in dangerous spot.
The only complaint I had about the valve is the oil flow was slow. Made the change take longer than it could have. I added greasing my zerks on my u-joints to the task nd that took up the time but I blamed the valve when I had the reach around at odd angles to get to the zerks at every change and deal with the grease mess.
It’s always something to think about - my Jeep pan could be hit by driftwood or brush - Lexus is just low & filter underneath …This is a good point. The location of the valve was beside the oil pan on my F150. I’d have some serious reservations about running one that hung down below the pan.
