Max A/C = closed heater core valve
st louis, mo
An interesting feature on my 1997 Ranger: when you turn the A/C all the way to the "max" setting, the valve for the heater core closes. So you cannot adjust the temperature of the air coming out the vents if it's on "max".
A plus of this system is if your blend door gets messed up, your A/C should still blow cold on "max". I don't think this design plays well with automatic climate controls though. Another plus is you don't have a hot heater core in the middle of your dash barely separated from the air flow.
Do you have a car that does this? I know the old Chevrolets had a "max" setting on the A/C, and I know they had a heater valve, but I don't know if they used this logic.
I bought one of these valves to use as an experiment but put it aside many years ago. Most vehicles don't have this as they want constant flow through the heater core so it doesn't plug up AKA Ford 3.0L Vulcan in the late 90s.
Thoughts:
1) I think the heater core on newer vehicles is part of the old "bypass" system. Coolant circulates in a cold engine through this system to heat it up evenly......even with the thermostat closed.
2) My 2005 Ranger (4.0l SOHC) has the same thing. Which engine do you have?
There's a 7" metal globe vacuum reservoir which pulls the coolant valve closed when you go to MAX.
It strikes me as a lot of hardware a simple cable controlled valve could've replaced.
That's funny, I had a '98 Ranger 3.0 that had a plugged heater core. Coolant was all rusty, too.
Even my 78 f250 has the vacuum actuated water valve that shuts off flow to the heater core with the ac turned on.
Here is something fun... My blend door on my Ranger HAS just failed. Since it cuts off flow to the heater core, max ac is still good and cold, but every other ac setting gets warmish air.
There is a new blend door from Dorman that has a metal square instead of plastic I have done a few
My 2006 tundra had a valve to quench the heater line. I don’t know the conditions under which it would close. Air was ice cold in that thing.
One thing for sure, on most modern cars, all air flow goes through evaporator. The blend door either sends it through heater core or not. If you want heat, normally the AC will not run and the evaporator will not be cold. If you want the defroster to run, the AC compressor will run, the evaporator will be cold, and drop moisture out of the system then the air will run through the heater core and warm up.
If you want cold air, the AC compressor will run, the evaporator will be cold and the blend door will bypass the heater core. The hot heater core with no air blowing through it will not contribute much heat to the system, making a heater core valve redundant. If people think it does, it might be because they had a screwed up bypass door, allowing heat into the system when the Ac was on.
My Lexus has "max cold." The other two cars do not.
What is sorta random imho, is, the min temp (assumption is all cars show a temp on display today). Usually it's 60 or 65F.
Say it's 55F outside, which is a pleasant temp. One sets their dash controls for 60 or 65, the minimum. Is heat added? I think so in the Lexus, and that's uncomfortable. net net is how does one get only outside air to come in. It wasn't too complicated when controls were analog and not all cars had AC
p.s. with our cars being 2006, 2007, 2011.....only the 2011 automatically engages AC when the recirc button is pressed. I happen to be of the camp that I do not want heat with my AC, unless it's a defrost scenario
