Started the wife's beater tonight, 2007 Camry, 2AZ-FE, 310,000 miles and smelled some burned oil inside the car, popped the hood and found a nice little surprise sitting on top of the exhaust manifold heat guard
Darn I guess the valve cover gasket has finally given up. As you can see it has been seeping for a long time but hasn't been creating any burned oil smell until tonight. I guess I'll be starting this project on a cold minnesota night
Here's the gasket, as far as I know it is original and it split on the front side right by the exhaust manifold which i'm sure is the typical failure mode. The whole front side of this gasket could be broken like glass it was so brittle, as well as the spark plug seals
I've posted about this car a few times since I have more or less maintained it since it has been brand new. It's never been victim of the notorious oil burning plague that infects many of the early 2az-fe's. This one has burned a quart of oil every 5000 miles since day one, and still to this day.
Oil changes have always been performed at 5000 miles using M1 0w20 AFE
here's how the valve cover and valve train looks after 310,000 and never being touched until a couple hours ago
Figured that i'd post some pictures since everyone seems to like internal engine pics
Also replaced the PCV valve, it still rattled a tad but you could tell it was a little gummy inside. PCV valve has never been touched either until tonight.
