Lol. Only Prestone can do advertising like that.View attachment 82293
@edyvw, should I tell my neighbor that he is good to go for another 100k?![]()
Thanks for the suggestion! I just flushed my 2017 RX 350(40k mi) with Bosch. Much improved breaking force. I wasn’t expecting such an improvement. Note that I believe the rears may have had some air in the lines.Bosch ES15-32N in everything. Extra mental comfort in the motorcycle, MB, and, admittedly, overkill in the others.
Plus it says I can extend to three year flushes vice 2 year flushes.
Bosch ESI6-32N
Glad you like it too and thanks for pointing out my typo.Thanks for the suggestion! I just flushed my 2017 RX 350(40k mi) with Bosch. Much improved breaking force. I wasn’t expecting such an improvement. Note that I believe the rears may have had some air in the lines.
Don't forget to replace your master cylinder and ABS module while you're at it.If I were to get my entire braking system replace all 4 pads,4 rotors,4 calipers,etc would I need to remove all the current brake fluid and put in brand new brake fluid?
No one can. Everyone has opinions, many people always buy the same brand so with no experience with other brands they can't qualify their thinking that one is the "best", and even when some group tests brake fluids, another group can test fluids and come up with a different "best".How in the world can anyone tell who makes the best full synthetic brake fluid?
I am bit sketchy lately about DOT4 in Toyota vehicles. I used ATE TYP200 in Sienna but master cylinder died. I mean it really should not be an issue in 2021, and it could be just bad cylinder, but I went back to DOT3 just in case.Thanks for the suggestion! I just flushed my 2017 RX 350(40k mi) with Bosch. Much improved breaking force. I wasn’t expecting such an improvement. Note that I believe the rears may have had some air in the lines.
”Need” is a bit strong, but if the fluid has been in there for more than a couple years, then now would be a great time. Vacuum out the MC (unless if that is getting replaced too?) then refill, then tear into the calipers.If I were to get my entire braking system replace all 4 pads,4 rotors,4 calipers,etc would I need to remove all the current brake fluid and put in brand new brake fluid?
There are some differences in cold temp viscosity between DOT 3 and 4 fluids. Some of the OE DOT3 fluids also contain higher levels of lubricants.I am bit sketchy lately about DOT4 in Toyota vehicles. I used ATE TYP200 in Sienna but master cylinder died. I mean it really should not be an issue in 2021, and it could be just bad cylinder, but I went back to DOT3 just in case.
Yeah there is discrepancy.There are some differences in cold temp viscosity between DOT 3 and 4 fluids. Some of the OE DOT3 fluids also contain higher levels of lubricants.
AutoZone seems to be the only place you can get Prestone MAX and they don't all have it available. I finally found a location with it in stock but four of the five bottles they had had broken seals. Good thing I only needed one.Anyone ever used Prestone Max DOT 3?
https://www.autozone.com/brake-and-...estone-dot-3-brake-fluid-32-ounce/1083029_0_0
I’m sorry to hear about that. As you mention, there’s probably not a strong correlation. I’ve been using AdvancedAuto Wearever DOT 4 in my wife’s RX350 for the last 26k miles and I’ll upgrade to Bosch for the next flush.I am bit sketchy lately about DOT4 in Toyota vehicles. I used ATE TYP200 in Sienna but master cylinder died. I mean it really should not be an issue in 2021, and it could be just bad cylinder, but I went back to DOT3 just in case.
This is definitely a thing and not just a 'buy OEM' scare tactic? Honda's DOT 3 is supposed to have some special sauce in it so now I'm second guessing my Prestone purchase.Some of the OE DOT3 fluids also contain higher levels of lubricants.
https://static.nhtsa.gov/odi/tsbs/2014/MC-10112028-9999.pdfThis is definitely a thing and not just a 'buy OEM' scare tactic? Honda's DOT 3 is supposed to have some special sauce in it so now I'm second guessing my Prestone purchase.
It is probably comparable to any generic DOT3 fluid.Now at this point I think that I am going to start using bosch brake fluid. About 2-3 months ago I had a brake flush and I had the mechanic use lucas full synthetic brake fluid. I have never used any Lucas products. Is Lucas brake fluid any good?
Don't forget to tell him Prestone makes an AMAM antifreeze that lasts forever.View attachment 82293
It’s a Subaru with almost 100k, so the coolant will probably outlast the rest of the car.Don't forget to tell him Prestone makes an AMAM antifreeze that lasts forever.
