I am currently using a Purolator PureOne PL10241 oil filter on my Toyota Tundra. I was doing some cross referencing and noticed that PureOne makes a full size (1 quart) oil filter. Part #PL30001.
Here are the specs on both filters:
PL10241
Anti-Drain Back Valve: Yes
Height: 3.36
Type of Filter: Spin-on
Threads: 3/4-16
Thread Pitch: UNF-2B
Relief Valve P.S.I.: 12-17
O.D.: 2.98
PL30001
Height: 5.14
Threads: 3/4-16
Relief Valve P.S.I.: 8-16
O.D.: 3.78
Before possible switching to a full size filter, I wanted to get some input as to whether the switch is worthwhile and safe.
What are the pros and cons in switching to a full size oil filter?
Will any damage result to the engine by using a bigger oil filter?
Also, I'm wondering about the difference in bypass psi. The full size is lower therefore, does that mean the engine will have a greater chance of getting unfiltered oil more often?
PL10241
Height: 3.36
Threads: 3/4-16
O.D.: 2.98
PL30001
Height: 5.14
Threads: 3/4-16
O.D.: 3.78
