Fuel Power + Seafoam, a redundent combination?
Wisconsin
Howdy folks, I just started running Fuel power in my car. I'm thinking about using Seafoam as a topend cleaner on the engine (pouring it in through vacuum line while motor is running) but im not sure if this would acomplish anything that fuel power isn't already doing (just slower)?
I know that Seafoam can also be used as a crank case flush but I plan on starting AutoRX soon instead.
Thanks
[ October 21, 2004, 12:00 AM: Message edited by: zugdud ]
I cant comment on Fuel Power, but from what I heard this stuff is great. As soon as I get back from the road I am gonna get some along with the Lube Control. As far as the Seafoam goes....Ive used it in all my cars and it seems to make a difference. The advantage to Seafoam is that it goes thru most of your manifold rather than just the combustion chamber. In my V-6 Contour that would have been a great help considering the intake on those things get gunked up all the time. Hope I helped.
Eric
No need for the Seafoam with the FP. FP can clean the combustion chamber just fine. Plus you don't have the hassle of the seafoam.
-T
