Originally Posted By: ekpolk
I think I agree with Bill on this, and in "direct proportion" to the cost of injectors. If they're really that expensive, even if they are the culprit, why not just select a slightly higher vis oil, and let the oil do its job (i.e. suck it up for you re the dilution)? Unless you're suffering massive, catastrophic dilution, I'd think that any decent 30 wt oil could protect your engine will over a normal OCI with "garden variety" dilution.
E.K. I might but the fuel dilution seems to have appeared out of nowhere then got progressively worse with each sample.
It's a bit better since replacing the Plugs/Wires previous to this sample but not by much.
I'm hoping the MAF/O2 Sensor work I did will correct it to an acceptable level.
If not I will monitor it over the next few used oil analysis and might just do a thicker oil to "suck it up" and RLI seems to be great from this because Terry said it did an outstanding job considering the fuel that was in the sample.
I just was discussing replacing the injectors here for discussion sake and for thoughts of maybe somewhere else to look in case it might be something I missed.
I think though I might just have it whipped with the O2's and MAF because the truck responds really well.
I have topped it off with gas this morning so I can see how this tank fairs in mileage versus my log book, but the Scangauge seems to be reporting better fuel consumption already so... Time will tell!
