So I just got my RLI sample test data back from Terry (See my other thread) and it was excellent except it had fuel dilution that was a cause for concern. Not exceptionally high, but needs looking into or else I can't extend my OCI's past 7K KM's (4K miles)
I cleaned my MAF tonight using the proper cleaner and rubbed the sensor wires very carefully with a Q-Tip coated in the cleaner. they were very clean already but I did it anyways. Then I sprayed it generously as well.
I also replaced the 2 up-stream 02 Sensors which had 200K KM's (120K miles) and 300K Km's (192K Miles) respectively.
Took the truck for a spin on some errands I had to do and noticed a big difference in performance and my Scangauge seems to be reporting less fuel usage per 100K so I will have to see if this fixes it for my next report.
Thoughts?
Thoughts?
