Please, please keep it up until the mods ban your IP(s).
There are plenty of dilution destroyed engines. Timing chains that have stretched and require replacement; cam phasers that have failed and been redesigned by the OEM; even probably some of the oil ring packs that between heavy loads of VII, thin base oils, high Noack, and fuel vapors, have coked up and either pass huge quantities of oil into the chambers or even score the cylinder walls.
There’s plenty of data that shows the effects of thin oils further diluted by fuel, if you’re not floating down the river Denial on a sinking ship. They’re just not present in engines with PFI only… which don’t pass as much fuel into the crankcase.
We don’t see these same failures on engines that use thicker oils and have similar dilution numbers. That’s called evidence.
