What are some of the effects gasoline might have on rubber seals over time via fuel dilution of motor oil?
Qlthough not the object of discussion, this thread is instigated by the still present condition of gas direct injected motors' propensity to seep fuel into the oil.
Important seals of concern are rear main seal, valve stem seals, oil pan gasket, and valve cover gasket.
Will the mix dry it out, make it swell, ect..?
