My Yugo didnt have syncromsh 1st gear IIRC. I learned to drive around it. Selecting reverse almost always requires double clutching.
I will say certainly blockers on 2nd and 3rd are really a downer.
If it is just first gear affected on a downshift, I would again bleed the clutch. I have had nothing but problems with hydraulic throwout mechanisms. If the pedal feels "spongey" or if it engages near the floor it need servicing. There is sometimes an adjustable link bar in the mix down at the slave cylinder which can improve pedal height if it has been assured that all air has been removed with a good bleed. I would NEVR assume the serving dealer ticked all the boxes. Just dont go too far with the link bar, there is a spec for the plate to disk pull off sometimes as tight as 0.03 inch,
Also running light grade crankcase oil or main bearing thrust flange wear can affect clutch action due to crank endplay.
- Arco
- Arco
