bubbasmith91
- Joined
- Aug 5, 2024
- Messages
- 16
I agree that it's a valve body issue. But it's 15 year old NJ car which makes it prime to rot out over the next 3-5yrs, so you can probably see why I'd like to tinker and see if I can't get it to resolve most of the way on it's own.IMO you are whistling in the dark and wasting your time & $$. The drivability symptoms you describe point to a valve body issue that needs to be addressed. Time to take your medicine and get it properly diagnosed at the dealer.
I figure at best the cleaning additives and new fluid help to clean some deposits and smooth out the shifting, maybe it smooths out quite a bit with full fresh fluid and some Lubegard - it's worth a try, for the $150 and some time put in, an extra $100 if my mechanic changes the filter, to see if I can get this to smooth out on it's own. At worst, it doesn't resolve much more than it has already, and I just changed the fluid and spent $250 for giggles.
If a fluid change doesn't resolve more than it has, the issue then becomes, it has been driven like this for 15k miles, and the assumption would be that there has been some damage to the clutches and/or bands. Probably not a high amount of damage, but enough overheating and slipping has been done in those 15k to cause some.
A new valve body from a Hyundai parts warehouse online is $1200+shipping, plus labor to replace it. Not sure how long it takes to replace a valve body on these.
I have seen several aftermarket Chinesium valve bodies around for anywhere from $250 to $800, but I feel like that's a bad idea.
So figure I'm looking at $1500+ to replace the valve body with a Hyundai one.
Getting the whole trans rebuilt or a reman put in is $2500-3000.
But it's a 15 year old northeastern car and imo even though it's a nice car, it's not really worth it to dump that kind of money into unless I simply don't have any other choice. I currently don't have the money to replace the valve body OR trans, I just want to mitigate the damage it's causing.
