Originally Posted By: 2004tdigls
this engine is notorious for oil consumption (my friends call it the vw 2.0/2 stroke, lol)
you need to get the engine looked at by VW and they may honour a tsb for the engine
VW Technical Service Bulletin 1701-01
http://autorepair.about.com/library/faqs/bl945d.htm
basically the rings were not installed properly (no stagger) or didn't seat in the block, turning your car into a 100:1 two stroke engine (lol i only drive vw diesels)
the 20w50 was used to hide the engine problem, the repair requires new rings and honing the cylinder bores, my friend had her engine repaired by the dealer under the tsb,
oh, you will also need a cat converter, its probably plugged with engine blowby
sorry for the bad news
This.
My sister had an '01 Jetta 2.0L and I was told the same thing by a guy who builds VWs. I put 15w40 in it and the car still burned a quart of oil every two weeks. It only had 110k miles on it.
