Seeing something is one thing. Accurately ascribing it to a particular cause is anotherI don't get how so many folks say they see lower oil temps when they increase grade. That's not how it works. Lower grade should run cooler oil temps.
People see what they want to see is basically it.Seeing something is one thing. Accurately ascribing it to a particular cause is another![]()
All kinds of HTFs. My first real job in the 1980's we blended HTFs. From earlier gen UCON fluids.I've read that before, from several sources. Some claim PAO offers better heat transfer. Not so sure about that.
"Lower operating temperature through better heat transfer and reduced internal friction"
Anyone remember Tooslick?
"The Series 2000, 0w30 generated the lowest oil temps I've ever seen in my Audi 100. That includes all the other Amsoil formulations. I've run everything from the Amsoil 0w30 to their 20w-50 racing oil in this 2.3L motor over the past 12 years....
Very effective friction modifiers and it transfers heat very well.
Ted"
Sometimes. Other times what they see might really be reality from their POV, but the cause is not clear. See the Boss filter thread running now.People see what they want to see is basically it.
People are notoriously bad at doing objective testing, it's very difficult to actually have a controlled driving environment outside so they attribute oil temps to the one thing they know they changed rather than the 8 other things they didn't control for.Seeing something is one thing. Accurately ascribing it to a particular cause is another![]()
But, but, but, lab testing is not real world!People are notoriously bad at doing objective testing, it's very difficult to actually have a controlled driving environment outside so they attribute oil temps to the one thing they know they changed rather than the 8 other things they didn't control for.
"What do you mean, you 'do your own research'? You running a double-blind study in your living room, dawg?"But, but, but, lab testing is not real world!
But, but, but, field testing lacks controls![]()
Thermal conductivity is pretty easy to look up. At least for base oils. Fully formulated mixes, with FM? Little tougher.I've read that before, from several sources. Some claim PAO offers better heat transfer. Not so sure about that.
Ted"
My favorite was a local kid that swore up and down that LM 5W40 ran 10 deg cooler than (insert whatever Walmart big-name 5W40 here). I have a graph somewhere posted here with a bunch of temp data with controlled (to a rasonable level) variables that showed that all the 40s I ran were the same w/r to temp for highway driving at least. I will say the HPL seems to run at a bit higher temp and I'd say that jives with the >4.0 HTHS vs. the others which will be <4.0.People are notoriously bad at doing objective testing, it's very difficult to actually have a controlled driving environment outside so they attribute oil temps to the one thing they know they changed rather than the 8 other things they didn't control for.
Yeah, I’ve heard that too that thinner oil should technically run cooler. But honestly, after switching to the Amsoil 5W40FS, I just noticed the temps were a bit lower, especially on the highway and the oil seemed to cool down quicker when idling after a drive.I don't get how so many folks say they see lower oil temps when they increase grade. That's not how it works. Lower grade should run cooler oil temps.
The issue is....you "noticed". Hard to say much with a bit more control over it is all I'm getting at. So many variables in oil temps - see my post above.Yeah, I’ve heard that too that thinner oil should technically run cooler. But honestly, after switching to the Amsoil 5W40FS, I just noticed the temps were a bit lower, especially on the highway and the oil seemed to cool down quicker when idling after a drive.
Maybe it’s not just about the viscosity could be the base oil quality or additives. Or maybe even just the old oil wasn’t holding up as well anymore. Not trying to overanalyze it, just sharing what I experienced.
Appreciate the input though always good to hear different perspectives!
Yeah, that’s true. I’m well out of warranty now, so it’s nice having some freedom to choose what works best. That said, I still try to stay close to VW specs when possible .Out of warranty, use what you like. The manual only gives you recommendations, not requirements.
If the oil is hotter, the engine is hotter. Where else would the heat come from? And where is that hotter oil going to?Maybe I’m misunderstanding but it thought if the oil temp was higher that was because it was absorbing more heat from the engine and therefore the engine would be running cooler
That’s not quite right. Oil and coolant both absorb heat, at the same time, they both release heat to other places. In a water cooled vehicle oil and coolant both play their part in moving excess heat out of the engine to the radiator and ultimately into the atmosphere. Oils might be equivalent in heat absorption, but do differ in ability to resist thermal breakdown.If the oil is hotter, the engine is hotter. Where else would the heat come from? And where is that hotter oil going to?
Absorbing heat from the engine is mostly the job of coolant, the heat capacity, transferrability, and viscosity is far and away better than oil. One oil isn't going to be drastically better than another in terms of heat absorption, but they can be better at reducing more friction.
