quote:
Originally posted by RalphPWood:
Ralph, i have a 1995 Ford Econoline 150 1/2 ton with a 5.8L (351 CID) Windsor. I would just like to install a Crankcase oil byass for now as thats all i will have money for ($200). Can you recommend me a good setup for my budget?? I want the best filtering possible so if it goes over 200$ i can deal with it but under 200 would be great - thanx. [/QB][/QUOTE]
The Frantz, Motor Guard and Gulf Coast 0-1jr all clean lube oil the same. Your engine doesn't know the difference. They are all designed differently. The element is what makes them superior. The Motor Guard is set up to seal inside the core of 1 5/8" tp. The Motor Guard as it comes from the factory is set up for 1 1/2" core Motor Guard elements. The Motor Guard elements are a special paper like coffee filter paper. The special elements have a core with a 175 F heat limit. It is the same plastic that they make gas cans with.
The Motor Guard is a one pass filter which gives it an advantage for what most Motor Guards are used for. Medical uses compressed air, etc. Motor Guard started in 1966 making only lube oil filters. They came out with a more expensive model later with a coating inside and out. It had 1/4" ports instead of 1/8" ports.
What I do is convert the industrial filter back to lube oil and fuel. It makes a nice filter. When they opened up the filters to get better flow that gave them a big advantage for fuel. They make me put flammable stickers on the fuel filters.
Getting to your question. It's not hard to keep it under $200.00 For the Ford I have a few Frantz dual filtration adapters. What drives up the price fast is if you need a bunch of hose. I have some Gates hose that is so tough that it is hard to get on the push on fittings. If you could measure from where you want to mount the filter to the full flow filter and email me the distance I can put together a system. I have 1/4" steel braid and fuel injection hose. We can work something out.
Ralph
[/QB][/QUOTE]
Yay!, Thanks alot Ralph. I really appreciate your expertise and help. I will measure and report back to you asap!
