This is the 2nd gen/non-OG filter with the cellulose blend media.I have to wonder if the center tube that Fram uses, there's not enough holes/holes not large enough...
as, I wonder if you had a Fram Ultra 2nd gen filter media with a E-core, if the end result is different or not?
That's what I wrote, in case you didn't notice.This is the 2nd gen/non-OG filter with the cellulose blend media.
It is the correct filter (the size Nissan specs)I was very surprised that the oil filter is so small.
Interesting - dealer must take advantage of volume purchasing by sticking to the 65F0E on everything. It does fit everything from Nissan/Infiniti vs the other way around.As far as I am aware, or at least so was the case at the dealership I worked at, they did use the 6607 size (Nissan 15208-65F0E) filter on everything.
OK, I clearly took what you were saying incorrectly then, I saw it as a posit on the media selection based on the "I wonder if you had a a Fram Ultra 2nd gen filter media" to imply this wasn't that, but you are in fact just wondering if it would look different with an e-core with this same media? If so, I'd say no, the distortion of the media is the result of it being cellulose and expanding, what's behind it is immaterial.
OP said it's been on for 18 months so where would 18 months ago place it in terms of being an OG or not?
To everyone asking, this filter was not wire backed. I got it in either June or July of 2021.
There's enough total flow area in the center tube holes. Only thing not enough holes might do is increase the total delta-p across the media and give less bypass valve opening headroom. The PD oil pump will ensure same flow if the delta-p across the filter increases some. If it was too much delta-p (like with choked off louvers) the bypass valve may open too soon. But Fram has most likely tested all their filters for delta-p vs flow and have set the bypass valve accordingly.I have to wonder if the center tube that Fram uses, there's not enough holes/holes not large enough...
Where are you seeing the date code? 163rd day of 2021 was before the change to the non-wired back media IIRC.
18 months ago would place it around July, 2021……..OP said it's been on for 18 months so where would 18 months ago place it in terms of being an OG or not?
Yep you were right with Jun 2021.18 months ago would place it around July, 2021……..
Man, the new blend media produces some ugly C&P's. Looks like it held up OK though.
That’s a new one, OG ones don’t buckle nor wave like that, the metal backing won’t allow it.OP said it's been on for 18 months so where would 18 months ago place it in terms of being an OG or not?
Geez … I’m trying to convince myself the UPF63 is good for 10kYou got 17000 miles out of that filter... I would say it did its job and then some...![]()
Never wavering LoL … I have a 10k new generation XG10575 waiting - I’m going to cut & post 3 filters off 5.3L’s soon with some context …Not a fan of the Fram shown here. Luckily, I have a bunch of old Ultras to use.
Maybe they should rename it UT... Undulating Tilde.
IMO the 7317 was one of the first ones to lose the wire. During the pandemic 7317s seemed to be difficult to find, they’re probably the most used filter out there.OP said it's been on for 18 months so where would 18 months ago place it in terms of being an OG or not?
Do you see how the media is not straight from bottom to top? "Wavy" is a term to describe the uneven pleats top to bottom.What does a wavy oil filter mean?
