FRAM XG2 - ~10,000km 6.4L SRT HEMI
OVERKILL
$100 Site Donor 2021
Ontario, Canada
This is the filter off my 2020 Grand Cherokee SRT, which has around 27,000km on it and was on the vehicle for just under 10,000km. This was the first run of @High Performance Lubricants Super Car 0W-40, first two OCI's were Ravenol SSL 0W-40. Unlike with the RAM, there was very little carbonaceous material in the bottom of the can and it didn't have the same greasy consistency as what was in the bottom of the filter in the truck. It was slightly thicker than the oil around it, but it would flow if you held the can on an angle, as illustrated.
View attachment 158630View attachment 158631View attachment 158632View attachment 158634View attachment 158635View attachment 158636
View attachment 158637View attachment 158638
Very nice write up. Good photos. Assuming more HPL went back in. What filter went on? Thank You
Could this oil filter have gone longer and how many more miles? I am guessing you played it safe because you were using an oil that is known for doing some serious cleaning?
One filter, one OCI, the HEMI's are dirty running engines, they've never been recommended for using a filter for more than one OCI and in fact there's an AMSOIL TSB limiting their extended drain interval due to the filters plugging up.
What sort of "dirt"? Carbonaceous, ferrous, other metallic, or what?
Carbonaceous. The semi-hemispherical chamber has great swirl characteristics at high RPM, but the reason it has dual ignition (16 spark plugs) is that the small quench areas on the sides of the chamber really aren't sufficient to cause it to behave like a pent-roof or a wedge at low engine RPM. It improves the manners, but ultimately it still runs pretty dirty, which ends up in the oil via blowby. I expect the issue is more pronounced on the 6.4L, which has huge (4.25") bores.
