Originally Posted by Triple_Se7en
Originally Posted by Vern_in_IL
Originally Posted by tomcat27
the black grippy coating on Fram filters makes them slightly larger - which renders some of the cap wrenches too small. I have the pliers, like above - but this is also another reason I use the Professional Fram filters - no coating. plus, the coating holds in heat.
Frams with the grippy coating are for HAND INSTALLATION ONLY. You are doing it wrong using a wrench. If that is a handicap for you, try another line of filters without the coating.
Some folks turning grip are not as strong as what's required, so the filter will not leak afterwards. It very-well may leak!
I add a quarter-turn with a wrench after hand-tightening and nobody will tell me I'm doing something wrong.
No sirreee!
As long as you can get it off to change it, it'll be OK. My issue is I always crank them on pretty tight by hand, and I'm not getting them off without a wrench-and the few times I try a cap style it strips right off. The band, strap and pliers always get it done for me, I haven't had to do a screwdriver impalement in quite a few years.
No sirreee!
