FRAM Ultra XG2 - 2020 Jeep SRT - Varnish?!
OVERKILL
$100 Site Donor 2021
Ontario, Canada
I'd say it's debris that the filter caught. Doubt it's actually "varnish" ... if it was, then there should also be the same varnish build-up going on inside your engine.
If it was debris, it should be in the media, not plated-out on the bottom of the canister, bottom of the cartridge and all over the bypass valve assembly though. That's my concern. Also, have no way to easily check what things look like elsewhere in the engine unfortunately.
ZeeOSix
$100 site donor 2022
PNW
The filter still has some oil in the media, it's the nature of the multiple layers of synthetic media, you'll never get it dry, so what you are mostly seeing is black oil, not carbon IMHO.
You can get it pretty dry if you wrap the element with many layers of paper towels and hold them onto the filter element with rubber bands. You might have to change out the paper towels a couple times over a day or two.
ZeeOSix
PNW
It probably is also in the media ... you just can't detect it.
OVERKILL
Ontario, Canada
You've tried this on an XG? I know it works well on conventional media, but hadn't tried it on an XG.
ZeeOSix
PNW
Yes ... just keep wicking the media like shown until the wicking stops. Might take a day or two with some paper towel changes.
OVERKILL
Ontario, Canada
Here's the previous filter, nothing plated out and it was run for almost double the duration:
Difference is that it was run from September 2020 to October 2021, so it was run through the summer before changed, and didn't sit, unlike this one, which sat for quite a bit during the cold months and didn't get much hot weather use.
ZeeOSix
PNW
I've see more crud in the same areas of the oil filters I've cut open if they were used over the winter months. My V6 Altima did that, and I could see more small carbon debris deep down in the media pleats.
OVERKILL
Ontario, Canada
Thinking further on this. Esters and many of the additives (detergents/dispersants) require heat to work. This vehicle sat while I was in the hospital, and sat for a month or so after I was out of the hospital. It might have got 1 or 2 short trips, that's about it, and in the dead of winter. It has only recently really had hot weather and the oil getting up to temp, and staying at temp. Given the "streaks" in the coating/buildup on the bottom of the can, I suspect had I run the fill through the summer like the previous one, the oil would probably have cleaned it back up.
