Filter was on a 2002 ES300 for 4 years, 2 months. 24,350 total miles over three oil changes. 332,400 total miles on the car.
- Impressive as it sits horizontally under the exhaust header, which will bake ADBVs and cause drain-down.
- Robust appearance and no visible dirt/grit in pleats or in filter body.
- Any damage pictured is from cutting open the can and prying out the filter (can somewhat crushed in removing and I clipped the ADBV with the snips when opening).
- You may also note the can defeated the (apparently cheap) tin snips I was using and broke the tip off.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I love these as I can skip the difficult filter change until the 3rd oil change, and not suffer for it. I replaced it with one I bought at the same time, back in 2019. This car was doing 15 to 20k miles a year, but not since Covid. New driver (my retired father) and much less miles. I refilled it with 5qts NAPA 10w30 full syn + 5ozs LubeGard Blue. I am not as strict about always using Mobil 1 10w-30 HM like I used to be; adding the LubeGard has made me relax a bit on that. Miles 150k to 300k were mostly all on M1 10w-30 HM.
This is what is so demanding on filters on this engine (Toyota 1MZ-E). Filter is right under the exhaust header. I have to use a claw wrench to get them out and that usually crushes them. Most filter’s ADBV will cook fairly quickly but the Fram Ultra ones never do.
