Originally Posted By: KD0AXS
Originally Posted By: mattwithcats
Fram 3614 and 3600 have same base and bypass psi...
I am running a 3600 instead of a 3614 on my other car...
Yes, the 3600 and 3614 are completely interchangeable as long as the extra length of the 3600 isn't a problem. I've interchanged them in several applications, including the Saturn in my signature.
However, the extra length of the 3600 is an issue in the Focus due to the positioning of the filter. The extra length makes the filter hang below the frame where it can easily be damaged. I'm not sure if this is an issue with all Focus models, but it's been reported by several Focus owners here.
Yes this.
The 8316 will not work properly, bypass settings are more than double that of the 3614 whereas they are identical on the 3600. But the 3600 is too long for the Focus, clearance issues.
