ok I have a 1986 vanagon, it takes a Mann W719/12 oil filter. I can no longer use that filter cause I added an oil cooler and sandwhich adaptor, so the stock filter is too long now to fit (hits the header pipe)
i looked up the filter specifications on the Mann website, the stock filter the vanagon uses has a 1 bar bypass pressure, and has an antidrain back valve.
i crossed referenced another Mann filter that has same specs, just in a shorter can. the correct one came up as W713/19.
I was not able to find that filter locally, so I bought a fram equivilant PH 8316 (supposed to be equivilent anyway) however I dont see ANY technical specs on the Fram webiste (it is very dumbed downed)
can anyone tell me where to find the spec on this fram filter?
I want to be assured this filter has the antidrainback feature and the 1 bar bypass valve.
also do you all know of other vendors that might have the Mann w713/19 or other equivelant filters?
note this fram filter (PH 8316) is cross referenced to fit the Jeep Liberty 2005-06 the Ford escape 2001-04 and the 91-96 Ford Escort
please let me know if this filter has the right bypass and drain back features to repalce the mann W719/12 filter I was using
