Fram PH 3600 at 5,000 miles. Torn pleats
Northern Nevada
Well this was a surprise. From my daughter's 05 Jeep Liberty. 5,000 mile run with 5w30 QS Full Synthetic. Don't think I'll be using these any more.
Very wide pleat spacing and long pleats is a recipe for media tearing on any oil filter. I think this is the first Fram with torn media like that I've seen posted here in a very long time. Typically the pleats will bend quite a bit, but not tear ... but not on this one.
Send this thread to Fram so the production guys can get their act together.
That looks like the infamous PH16 ones of old, somebody (or some machine) screwed up pretty badly. Normally cutting open a filter voids a warranty, but I bet Fram would like that one back.
The 3600s that I've seen here usually have much tighter pleats, and look very good. Its the reason why I've decided to move from the OEM recommended 3614 to the 3600 for my Sienna & Highlander.
Bad spacing = no support = easy tear area.
This could happen with any brand.
Last filter I cut open was a cheap pro tec. Looked real good for a 1.?? Rock auto filter. Looked like a Purolator to me.
When was this beauty manufactured ?
Wonder if this championship level filter was made after the change over of ownership ?
We saw a Fram 6607 with a very wide pleat spacing on it big enough for it's own need for a space for rent sign....
The tough guard is known for much better pleat spacing and quality. They also have more pleats. like 15% more or so. But the ph3600 is longer than the 3614 and i can imagine a shorter filter is possibly more stable and rigid but that's more of an assumption. But 5k on a 3600 size is almost nothing. A ph3614 should still be able to go 10k. But i'd probably go for the tg3614 instead of the ph3600 for those short intervals.
I recently cut open my EG (PH2) from my F-250. 5k miles on it and not a thing wrong with it. I didn't post it because I don't really see the value in showing something that's perfectly fine.
I think there's obviously some variation in the quality of the EGs. Some are perfectly fine; others have some pleat/void issues such as this example.
Why buy the cheapest filter on shelf ?
Supertech is cheaper.
Plus many times cheaper is just as good as more expensive.
As for this filter, as said, long filter with very wide pleat spacing near the crimp is just a tear waiting to happen.
Hopefully this is an isolated incident and does not turn into another Purolator like tearing issue.
