- Joined
- May 5, 2018
- Messages
- 27,813
When you get a great product and it's inexpensive you appreciate it.I figured I would get an answer like that.
You have done a good job finding a good and cheap filter for $4 No wonder you are so rich![]()
I do anyway.
Iām not sure, Iāll look at it in the morning. I was going to dissect it this weekend but was considering contacting Fram and seeing if they would do anything.This failure is surprising, haven't seen exactly like this one. Wondering if the media where it meets the end cap lacked glue there and the pleats were pushed inward from the oil flow dP. It's going to need more inspection to try and determine why it failed. It the media still attached to the end cap where the media blew inward?
Iād do that asapMaybe I switch to Premium Guard filters.
Give him a break Jim. Itās Friday. I saw enough tearolators to last me for life. Iād go Donaldson route before Purolator.Thanks for repeating the Boss dribble for the 7000th time.
You'll never see me with one![]()
Should be able to look up through the gap with a good flashlight and see if there is still some media glued to the plastic end cap or not, without dissecting anything.Iām not sure, Iāll look at it in the morning. I was going to dissect it this weekend but was considering contacting Fram and seeing if they would do anything.
It's an inside joke Adam so give me a breakGive him a break Jim. Itās Friday. I saw enough tearolators to last me for life. Iād go Donaldson route before Purolator.
Agree, that it is an odd appearing failure. Wonder if there was strain from twisting on install that would initiate the tear or like you stated insufficient glue. That just doesn't just "happen" in a tight pleat area given a relatively even pressure gradient.This failure is surprising, haven't seen exactly like this one. Wondering if the media where it meets the end cap lacked glue there and the pleats were pushed inward from the oil flow dP. It's going to need more inspection to try and determine why it failed. It the media still attached to the end cap where the media blew inward?
Youāve had plenty of breaks Jim. What color is your oil filter? J/kIt's an inside joke Adam so give me a break![]()
Metal flake blueYouāve had plenty of breaks Jim. What color is your oil filter? J/k
BOSS.......... Thought āblack is where itās atā per quote
I got a dozen of Royal Purple filters the other day in sealed boxes from late 2019......they may be great filters like the OG?. Thought āblack is where itās atā per quote
Doāh! Shoulda knownBOSS.........
Iām waiting on the cut and posting the filter from the CenturyTomorrow afternoon Iāll get some up close pictures of where the media meets the end cap. Might take my endoscope and go up inside the tube as well. Going to wait until after I speak with Fram next week before I cut it apart just in case they want me to send it to them.
