Or remove all the metal and copper from the charging stations to sell at the recycle center.I can forsee in 20 years homeless camp would also have charging station, and homeless will charge their "home" about twice a day.
with enough voltage everything is possible.
imagine this happening during chargebatt-cells be like popcorn.
Doubt it. Do you see homeless campers or anyone try to pry open gas station to pump gas out of underground tank?Or remove all the metal and copper from the charging stations to sell at the recycle center.
People man gas stations 24/7. People don't man EV charging stations 24/7.Doubt it. Do you see homeless campers or anyone try to pry open gas station to pump gas out of underground tank?
I don't "need" faster for my Prius Prime but I do like it. I only have 26 miles on electric. My kids' school is 15 miles round-trip. I can run a kid there for track practice, come home, charge, then return to the school two hours later for pickup and make both trips without burning gas.You don't need anything like that. I have a 240 Volt, 40 Amp service and my Tesla usually charges after typical use in 30 - 90 minutes. Why would anyone need anything at home faster than "overnight"?
Agreed. 240 Volts at 40 Amps is a lot better. Power = Current (Amps) X Voltage (Volts) or [Voltage squared divided by Resistance].I don't "need" faster for my Prius Prime but I do like it. I only have 26 miles on electric. My kids' school is 15 miles round-trip. I can run a kid there for track practice, come home, charge, then return to the school two hours later for pickup and make both trips without burning gas.
I crunched the numbers, 2.8 cents per mile on electricity, double that on gas.
Car came with a stupid 120V, 12A EVSE but it's a known hack that the same "guts" work on 240 overseas. So I made up a little adapter to a NEMA 6-20 and it charges at 11 mphs on 240/16 vs 3.5 mph on 120. This is hardly a huge load on the grid but gets my car charged up in 2:40 vs 6+ hours.
Not around here. They don't always man the station, just turn off the pump at night.People man gas stations 24/7. People don't man EV charging stations 24/7.
Where I live (and where there's a lot of homeless camps) service stations are open 24/7 and manned at all times. Regardless, EV charging stations aren't manned no matter where they are ... so open to vandalize and theft - that was my main point.Not around here. They don't always man the station, just turn off the pump at night.
You would get three phase power. Rectified single phase is such lousy dc power that it would have other negative ramifications at those power levels.And if charging at home, assuming you want full speed charging, would you need 400 amp or 600 amp service?
So the power company will dig the existing buried cable and replace it with (larger) 3 phase? At least here in South Carolina is it the rare residential property close enough to a 3 phase line to get a drop. GREAT idea, but it won't be easy to implement.You would get three phase power. Rectified single phase is such lousy dc power that it would have other negative ramifications at those power levels.
The average customer won’t be charging at these rates.So the power company will dig the existing buried cable and replace it with (larger) 3 phase? At least here in South Carolina is it the rare residential property close enough to a 3 phase line to get a drop. GREAT idea, but it won't be easy to implement.
Maybe if it’s your only car and you take long road trips frequently or have to drive for a living. For the average person who works 5 days a week and lives within a reasonable distance to their place of employment, it’s a total non-issue. Charge it when you get home, leave with a full battery every day.
How many of people own cars there? I mean, if 2/3's live like this, but only 1/3 own a car, then isn't the problem a lot smaller?try to explain that to these people.
btw, 2/3 people in europe are living this way...
At one point wasn't ICE in the category?That makes EV’s sound like toys for the well off.
you guys seem to be openly admitting that EV’s are entirely inconvenient for travel beyond a normal commute. Not great for anyone who can’t afford a second car or who has needs beyond that of a typical urban EV consumer.I'll say it again. You don't need 600 Amps or 400 Amps or a 3 phase connection to charge an EV. To have a practical Level 2 charger at your home you need a 240 Volt 40 Amp outlet. That's similar to the requirements for an electric range. And that's all anyone with a reasonable commute needs.
If your commute can't be completed by a Tesla charging overnight at a 240 Volt 40 Amp plug in, you have bigger problems than your electrical system.
No perfect solution, but I'm not sure that every apartment needs a charger.
True. But various things get mandated for our own good all the same.No one mandated conversion to ICE either. No surprise wealthy urban folks don’t understand the hesitancy of dissimilar folks.
