Yikes, suddenly changing a timing belt every 105k doesn't seem so bad.
The chain driven water pump in my '96 Maxima failed around 200k. Coolant leaked externally as designed and Nissan was thoughtful enough to put a metal access panel in the timing cover to remove/install the pump through, making it a fairly easy repair. I'd venture a guess that the VQ30 is shoehorned in this car a bit tighter than your average DOHC V6 in a medium size crossover, so I have to wonder why Ford couldn't have done something similar.
