I've done quite a few of these & have done it by Removing the powertrain & by following Ford's service procedures which had you almost take the engine out & fight with everything.
In my opinion, It's easier to just drop the Powertrain.....Especially on the Edge & Lincoln MKZ. The Mazda CX-9 calls for engine removal in Mazda service information & it's the same platform from what I can tell.
The Ford Flex has more room & haven't tried removing the Powertrain for a water pump yet.....But I'll likely try it next time just to see if it's worth it.
I also believe the customer gets a better level of workmanship this way, Especially with prepping & sealing the Timing Cover.
This one was caught early & was only leaking out the weep passage as designed, No oil contamination, 2008 Ford Edge with 165,xxx miles.....Owner takes pretty good care of it as ya'll can tell.
