Originally Posted By: wag123
Originally Posted By: supton
I suspect Tundra's are pretty close to the bottom at the moment. World class in half-tons in 2007 when they debuted the 5.7&6spd auto, but they simply have not kept up. Now they are merely "just good enough".
And, you would be wrong! You need to take a close look at the 2014 Tundras, and take a test drive.
Not shopping at the moment for another truck, and certainly don't want to be tempted anyhow. Plus, 2014 was sheetmetal changes and not much more. Maybe they played with spring rates, noise deadening. I have heard they did reprogram the accelerator pedal, something long in the coming. Maybe they fixed cruise control too? One can hope. Perhaps they finally got auto up on the electric windows too?
They also are rather behind in the mpg department. They use nada for mpg boost. The 4.0 is too little motor IMO, and my 4.6 is "good enough" for my light usage; but the mpg's pale in comparasion to GM/Ford/Dodge. Which I was ok with, as I didn't plan to rack up mile after mile, and being a Luddite I didn't want any of the fancy tech.
Quote:
IMHO, the Tundra is the best built most reliable truck you can buy. Their 5.7L V/8 is strong and bullet-proof, and all of the other mechanical components are hefty enough to be used in a 3/4 ton.
Dunno, they have their issues. AIP, steering rack, front diff, water pumps. I just had the front diff rebuilt at only 84k. Given how little 4WD this truck likely has seen it's a bit sad; and Toyota has a TSB on it, so it's a real issue. I think the 5.7's may have rear diff issues too: get this, turns out the 4.0/4.6 rear end holds one more qt of gear lube as compared to the 5.7, despite the 5.7 rear having a larger diameter ring gear!
Whatever the components are, the axle limits aren't that high, and the payload is low. Perhaps they are oversized and bolted to an undersized frame? Why not beef up the frame--or just try to break into the 3/4ton market?
Quote:
The icing on the cake is that they are ALL built in the USA. Many of the Fords, Chevys and Rams are built in Mexico (look for a 3 as the first digit of the VIN). The quality of the Mexican built trucks is definitely sub-standard compared to their American built counterparts.
No comment, don't have any info on this. Yes it's nice to have them built in the USA. Not convinced that quality control respects country boundaries.
Quote:
But, Tundras are pricy.
Sorta. All trucks are pricey, but looking at my local dealer I didn't think they were too bad. They seem to hold their value, which is rather neutral: bad when buying, good when selling. New double cabs are low 30's, used 2nd gen I think is still low 20's/upper teens, depending upon miles. Which means they are a good deal, if they can truly withstand high miles and years of use. Which is more or less what got me to buy one.
I like my truck, I did buy it for a reason; but while I'm a fanboy I'm not oblivious to its shortcomings.
