Originally Posted By: Gary Allan
Quote:
If 20-weight oils were the Holy Grail, companies like Mercedes Benz, Porsche, BMW and the like would be using them in their high output engines. But that is not the case, is it?
They tend to make different kinds of cars, don't they?
Let me turn it around for you. If using 40 grade synthetics was such a Holy Grail, how do our common passenger car engines in pickup chassis manage on a 5w-20 or 5w30 spec ..while being fully capable of pulling full capacity up 6% grades ..and only suffer a shortening of the oil change interval?
btw- MOST of the Euro's that are heralded here tend to have bigger sumps and longer drains. Detune those sumps to US typical, and see how their drains shrink under those conditions.
What you're seeing is two inverted coping mechanisms ..but viewing them only from one angle.
Easy:
Most of the engines from those Euro manufacturers make significantly more power per cubic inch.
Note that we do NOT have the 425HP version of the 5.4L here. And the 5.4L we DO have, now has a 7L sump and a massive oil cooler. And still only makes 300HP.
Mercedes has engines in that displacement range making over 500HP!!!
And to reinforce this, for Ford's own high-output engines, such as those found in the Ford GT and GT500, they DO spec a heavier oil, a MUCH heavier oil in fact! 5w50!!
