Don't mind SteveS, he's here to balance out those who want to do stuff. He's the guy with the halo or pitchfork on either shoulder depending on which way you're looking at it. You'll only find enablers here otherwise.
Okay ..hmm.. where to start here.
Are you saying that you (essentially) want to run the bypass filter in parallel to the full flow?
Fine ..but you'll have very little differential across the full flow, so the flow through the bypass will be limited. It will still work.
Q: why the remote mount?
Reason I ask is that you can probably spend less money by getting a Permacool sandwich adapter and just plumbing the bypass filter to it.
When you do that, there's no need for a bypass filter with a built in restrictor. You can even use the Ford mount if you want to use a combination full flow/bypass
Part Number: 51641
UPC Number: 765809516410
Principal Application: Nissan UD Trucks
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: By-Pass
Media: Paper
Height: 6.601
Outer Diameter Top: 4.276
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: None
Burst Pressure-PSI: 345
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 12
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
You can also use a hydraulic mount (cheap) for this filter
Part Number: 51091
UPC Number: 765809510913
Principal Application: Chevrolet, GMC, Isuzu Trks 4-Cyl 2.2L Diesel Eng (84-87)
All Applications
Service: Lube
Type: Full Flow/By-Pass
Media: Paper
Height: 5.225
Outer Diameter Top: 4.300
Thread Size: 1-12
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 275
Max Flow Rate: 12-16 GPM
Nominal Micron Rating: 6
Gasket Diameters
Attached 3.052 2.470 0.173
Packed 0.716 0.498 0.109
The gasket is a bit bigger, but would probably work.
