I’m wanting to buy a foam cannon to use with my Simpson pressure washer. I’ve watched a bunch of comparison videos and they never seem to agree. What do you guys recommend? I’d like something that prod thick foam. Thanks in advance!
I use the automatic car wash. $8.00 and the clean is good enough.I've watched the detailing videos where they use foam cannons, but don't get the appeal. It looks cool and all with the car covered in foam, but around here, half the foam would dry up before you could wipe and rinse it off. I prefer the bucket and wash mitt so I can do one or two panels at a time and use a detail brush on moldings and emblems.
Same!
That is my foam cannon. It is installed with a 1.1 mm jet but comes with a 1.25 mm jet. FYI the 1.1 mm is better for a lower pressure electric pressure washer. Yes… I just cleaned the foam maker “pill” with baking soda. I am now storing the cannon with the nozzle up and the bottle off to drain the foam maker. So far this is my second cannon and I like it despite having to clean the pill. I like the wide mouth also has another screw on fitting for a soda bottle. The suction tube is weighted and very flexible.I own this and very much dislike it. The black finish inside the body flakes off and plugs up the pill. Also overall it needs a pill every year regardless if you flush it or not......
Brilliant Finish™ Foam Cannon
Create rich, clinging foam and have more fun washing your car. The Cannon coverts your favorite car wash into a powerful foam that loosens dirt and grime and brings out the shine. Prevent wash-induced scratches.www.griotsgarage.com
I've read the problem with these is the narrow neck of the bottle breaks. Could last for ever though but worth it to be careful and not handle it roughly.Same!
It shoots some serious foam. I rarely use it though with my vehicle wash routine.
This HF cannon worked great, washed my truck yesterday and it put out thick foam, I use Meguiars Gold Class Shampoo, like the wide base and mouth, thinking of getting another one for my ceramic spray rinses.Picked up a Harbor Freight foam cannon today, good reviews on YT, will try it out tomorrow.
