Fluid temps when it's cold out
My wife and I went for a wee tour this evening, it's a bit colder. Took quite a bit longer to get up to temp too.
-28C is -18.5F.
I should sneak there and unplug your seats. I see you've been using them.
Your experience with an oil/coolant heat exchanger is right on the money.
On my vehicles without one, the oil temp lags the coolant temp significantly and does not get to "normal operating temp" even after long continous runs. This has been my experience with both Modular V8's that had oil temp sensors. A 4.6 L V8 3V with a 6 qt sump and and a 5.4 3V with a 7 qt sump. Oil temps in below zero weather would stay a solid 20+ degrees cooler than regular weather even after long runs over an hour...
On vehicles with an effective exchange, they stabilize as normal.
-28C is -18.5F.
Nice Metallica song you’re listening to BTW
