Fluid recommendation
Georgia
Planning on doing a power steering fluid swap using the turkey baster method on my 04 Toyota Tacoma 3.4L. Manual states to use Dexron III ATF. What's a good brand that will work in a P/S type application. Also if I use the turkey baster method several times, will I eventually replace all the fluid, or will the fluid near the rack and pinion remain?
I used Valvoline Dex/Merc and Maxlife Dex/Merc in my 98 Camry. It had a slow leak when I got it, and fresh fluid seemed to speed it up somewhat. The Maxlife didn't make a noticeable difference, but a bottle of Lucas PS stop-Leak did. The old fluid was very dark, with globules of a whitish substance floating in it, so I suspect there was some stop-leak in there.
That said, any Dex-III compatible fluid should work fine, and Dex-VI is an upgrade. The turkey baster method will get fresh fluid into the entire system, since it's moving through the rack and pinion every time you move the steering wheel. I don't know what percentage of fluid sits in the hoses and rack, but a fresh reservoir, followed by a drive, and another fresh reservoir should replace most of the old fluid. Then do drain and fills at whatever interval you're comfortable with, and the system should stay happy.
Originally Posted By: mclasser
Originally Posted By: michaelluscher
Maxlife.
Syn, cheap in Gallon jugs, what more do you want?
+1
+2
