Fluid Recommendations - 02 Camry
Scituate MA
New to me, 2002 4 cyl Camary, 100K. I just got it about 4 - 5 months ago and need to change the fluids.
Oil - I will use Mobil Syn
Power Steering - ATF Dexron 111 (Nothing better is there?) Turkey Baster?
Brake Fluid - ? Turket Baster?
Transmission - .dealer or Mobil 1 Fully Syn ATF
Coolant - ? For coolant is there a drain plug on the rad? There is the plastic apron under there so didn't immediately see a drain plug.
Is the fuel filter accessible?
Advice / recommendations?
Thanks.
M1 in the transmission and power steering on my similar Highlander. Working well.
Coolant, yes there is in the middle. I would use Toyota Long Life Pink.
I use whatever synthetic oil, 7500 miles, and things look pretty good.
