Lubegard Power-Steering Fluid (PSF) Recommendations From Manufacturer
Winnipeg MB CA
I look after the four vehicles in the family -
2002 Mazda MPV 3.0
2007 Dodge Grand Caravan 3.3
2009 Mazda5 DOHC 2.3
2009 Kia Sedona DOHC 3.8
We have severe winters here, and the Dodge's PS pump growls all winter, basically as soon as the temperatures drop below freezing.
I've siphoned out and refilled the PSF reservoirs on all four vehicles regularly.
Refills to date:
MPV - Valvoline MaxLife MV ATF (which meets the Mazda M-III spec for ATF to be used as PSF)
Grand Caravan - Whichever flavour of ATF+4 I'm using for the current ATF drain-and-fill
Mazda5 - Recochem OEM Asian-vehicle PSF
Sedona - Recochem OEM Asian-vehicle PSF
Anyway, I've heard good things about Lubegard's PSF quieting down growling PSF when nothing else works, and also thought that I'd like to standardize on one PSF for all vehicles.
I found the Lubegard website a bit confusing, a bit like trying to drink out of a firehose.
I emailed them yesterday, listing the four vehicles and the factory recommendations for PSF, and got a nice reply within a few hours. Lubegard recommends the use of their 23232 PSF in all four vehicles. I ordered some last night, and am looking forward to trying it.
https://lubegard.com/product/complete-synthetic-power-steering-fluid/
Coming back Alaska our RV's (04 Chevy Express) power steering kept getting louder and louder. At a rest stop in the middle of Montana I did 2-3 reservoir swaps and after few miles its got quieter and no issues since. That was a couple years ago. Just did the Dakota's but haven't put that many miles on it. Good stuff like most of their products. They have a separate product for Honda's.
2002 Mazda MPV 3.0
Refills to date:
Sounds like a good move. In recent years, I started using Honda Power Steering Fluid in all PS systems.
2002 Mazda MPV 3.0
Refills to date:
I put ATF in everything.
2002 Mazda MPV 3.0
Refills to date:
CHF11s is typically the bees-knees for cold weather.
That's often the factory recommendation - but apparently a dedicated PSF can give better results.
I guess I'll find out.
I haven't had to replace a power steering pump since I started using only ATF in the power steering in the late 1990s.
I'm not sure what advantage dedicated power steering fluids are supposed to give.
If the Lubegard quiets down the PS pump in the Dodge, I'll be happy.
Just got done changing my power steering fluid 30 min ago. Did it yesterday too. Looks like I may have to go 3-4 intervals to clear it up. The fluid looks great, it's a bright red fluid. I've used Mobil 1 ATF the past 15 years.it takes a while to flush out the old stuff. Don't waste your Lube guard trying to flush out old stuff. Just a FYI for ya. I'm putting in some AMSOIL power steering fluid slowly. Good luck.
Not a 100% on it but my understanding is the Honda Power Steering Fluid is slightly thicker, and the biggest their systems typically use different seals which don't play nice with most ATF.
You can search BITOG and the Honda fluid does have some kind of magic in ít.
I believe that is correct. Higher viscosity, some sort of magic for their elastomer seals, and friction modifiers. There has to be something different enough that it never makes it on the "multi-use" fluids.
