Unless you are regularly clogging up the media during an OCI (which implies a more serious problem) then increased filtration area isn't relevant. What is relevant is higher filtration efficiency.
You’re always free to do what you want… but unless you’re leaving your 820S to the point it’s completely loaded, more media won’t do anything. As a matter of fact, more media will actually pass a HIGHER amount of particles through. It’s simple math since more filter media is still only 95-99% efficient. Plus the smaller filter should begin to plug some of the smaller holes and the efficiency will rise quicker.OK, here's my reason. I don't use the (thinner than water) 20 weight or even (thin as water) 30 weight oil manufacturers recommend. I run FULL SYN 5w40 in everything. And I'm not concerned about an extra couple ounces of capacity. I'm looking for MORE square inch's of filter material. If you think the smaller filter is adequate, good for you. I didn't come here for an opinion on weather I needed a longer filter or not. I made that decision all by my self. I simply asked if anyone knew of a longer filter for my 4.6 ford that took a 820 filter for years, and now Motorcraft has added an "s" to the filter and makes them shorter. (reducing capacity) .
And I THANK everyone that gave "HELPFUL" info. While I'm at it, I'll answer a question BEFORE it's asked. I know an old engineer from GM. He told me GM spent MILLIONS........ MILLIONS of dollars to gain 1 MPG "FLEET AVERAGE" (a big deal with EPA mandates) When GM went to "THINNER" oil, they gained 1.2 MPG across the fleet average. FREEEEEEEEEEEEEEEEEEEEEEEEEEEEE ! They would run 5 weight if the engines would live past the warranty. And listen to the CASTROL oil commercial if you can still find it. They say CASTROL gives superior protection to ANY OTHER 10W30 weight oil. Why you ask??? Because any no name 40 weight will out perform the BEST 30 weight. And look at this -> JMO.
And for the “pleat counters” - it has been mentioned these ^^^ and Royal Purple trap in more of a 3D manner …If you are concerned about filter media area, run a synthetic media filter like the AMSOIL EaO or the FRAM Titanium, which still uses the old XG multi-layer synthetic media.
There are significant variations in media surface area between filters for the same application, for example the PureONE has more media than other filters.
Not true. More media area (with all other factors constant) would decrease the delta-p across the media, and that would help keep already captured particles in the media. This was seen by Purolator/M+H research, and also seen in the filters tested by Ascent Filtration Testing. Part of an oil filter's overall ISO efficiency rating is dependant on how well the oil filter retains already captured particles. If the media starts sloughing off captured partucles as the filter loads up and the delta-p increases, then it becomes less efficient as it loads up, and the overall efficiency will decrease.You’re always free to do what you want… but unless you’re leaving your 820S to the point it’s completely loaded, more media won’t do anything. As a matter of fact, more media will actually pass a HIGHER amount of particles through. It’s simple math since more filter media is still only 95-99% efficient. Plus the smaller filter should begin to plug some of the smaller holes and the efficiency will rise quicker.
Not true, the opposite happens.... the bigger filter with identical media will actually increase your particle counts.![]()
Filter designers will use more media area if required to: 1) Decrease delta-p, which also helps increase efficiency, and 2) Increase holding capacity.There are significant variations in media surface area between filters for the same application, for example the PureONE has more media than other filters.
Most full synthetic media oil filters will have less media area, which will "throw off" most filter "analysers" because they think "more media is better" regardless of the media type. But if you simply look at the rated ISO efficiency and the holding capacity (up to milage use rating), that tells a lot more about the filter media than the total area.If you are concerned about filter media area, run a synthetic media filter like the AMSOIL EaO or the FRAM Titanium, which still uses the old XG multi-layer synthetic media.
Yes, though we don't know how much of that performance they retainedFilter designers will use more media area if required to: 1) Decrease delta-p, which also helps increase efficiency, and 2) Increase holding capacity.
When the Ultra changed to the new media, they used much more media surface area to retain the same performance as the wire backed "depth filtering" media (efficiency, holding capacity, and delta-p vs flow).
Yup.Most full synthetic media oil filters will have less media area, which will "throw off" most filter "analysers" because they think "more media is better" regardless of the media type. But if you simply look at the rated ISO efficiency and the holding capacity (up to milage use rating), that tells a lot more about the filter media than the total area.
Yep, it's too bad the new Ultra design wasn't out when Ascent Filtration Testing (Andrew) did his certified ISO tests. It would have been interesting to see the OG vs new Ultra in the same filter model number tested side-by-side.Yes, though we don't know how much of that performance they retainedThe filter was clearly overkill, losing a bit on those parameters likely would be inconsequential.
Was thinking the same.Yep, it's too bad the new Ultra design wasn't out when Ascent Filtratiin Testing (Andrew) did his ISO tests. It would have been interesting to see the OG vs new Ultra in the same filter model number tested side-by-side.
I'm pretty confident that there wouldn't have been much difference. Fram claims the efficiency actually went up on the filter model number they compared. The new Ultra is still rated at 99+% @ 20μ and rated for up to 20K miles, so the performance couldn't have changed much to retain that level of performance.
