Ed_White
Compared to the FL-820S, the Fleetguard LF3681 had an inferior anti-drain back valve (nitrile vs silicone for the FL-820S) and an inferior pressure relief valve and it cost more (plus it is not readily avaiable). The qulaity of the media was similar, at least in appearance. The Fleetuard media was slightly thicker, but the surface area was about the same. There is a Fleetguard FL-820S equivalent filter with "better" media avaialble - the LF16002. I have one of these on order. Prehaps you cut open one with the better media? My main knock against the Fleetguar LF3681 is the anti-drain back valve. It was nitrile and not even a good nirtile design (in my opinion). I would not use this filter on a Ford modular motor.
Ed
Ed
