Originally Posted By: NHHEMI
Originally Posted By: Doog
Do the repair and have the body shop buff the whole car. You will get it back.
That spot of damage is going to drop you down on your trade a LOT. The better shape the vehicle is in the fewer things the dealer has to lower the price and thus the more you will get.
It comes down to return vs investment. If spending $245 on the repair( and say another $100-$150 for a detail )returned you only $300-$400 extra on the trade it is not worth it( you could even lose money ). However if it returns $1000+ then you made money. You need to get an idea of what your vehicle is worth book value before going to the dealer with and without that damage. 99.9% of dealers will go with KBB or NADA on trade values. Any deviation is them doing funny money to make you think you got more for trade then you did. Know before hand what you should be getting.
IMO fix it for sure. Have that spot fixed and then clean the vehicle top to bottom and have it buffed out as Doog suggested. It will pay off.
Not knowing the exact particulars on your vehicle other than year and model I sort of guestimated at stuff and just went with the middle on options and such to get an idea. On 2011 Camry LE w/ 60K and basic options the trade values( KBB )are listed below...
Excellent
$11,829
Very Good
$11,529
Good
$10,929
Fair
$9,329
It all depends on mileage, options, and how well taken care of your vehicle is of course. These are just some rough numbers to show if it is worth it or not.
It is almost impossible to trade a vehicle and have the dealer agree the vehicle is Excellent. Can happen but rare. Usually Very Good is tops. Let's see some scenarios...
I. Let's assume your vehicle is Excellent. The damage would absolutely drop you at least one grade if not two. So if it only dropped you to Very Good you would only lose $300 in trade value and that is not worth your time and effort to try and get back and may even cost you more than that to do so. Don't fix it. However, if it dropped you down to Good you would lose $900 and that is worth you fixing as it would net you a gain of somewhere around $400-$600.
II. Let's now assume the vehicle is Very Good which is possible and even likely w/ a 2011 if you took care of it and it is in good shape other than the damage. If the damage drops you to Good you lose $600. If it drops you to Fair you lose a whopping $2200. Some dealers will clasify your vehicle as Fair with any kind of damage. It is worth fixing regardless of a one or two level drop. You make money doing it.
III. Let's now assume the vehicle is Good in the dealer's eyes for whatever reason not including the damage. The damage drops it to just Fair. That is a $1600 loss for you.
It may be extreme according to some others to suggest that a 4" area could have such an impact on the grade but I am not so sure of that. I do know for a fact that on a newer vehicle like that, the better the shape it is in, the more you will get for your trade. Dealers do go by KBB & NADA so it gives you some good insight before even going to talk trade as to what you can expect. To me on a 2011 making a $245-$400 repair to the exterior is worth it( as long as it runs good and is in really good shape otherwise )as it will pay off with a higher trade in.
Most dealers go by KBB or NADA when it benefits them (on the sale end.)
Most dealers use Black Book when they take in a trade, which is basically wholesale.
