The metal backers swole so bad it got stuck? Sounds like what happened to my aunts car.File to fit. Had to do that for years.
I try to take the caliper bracket off, clean under the shims, but often pads just don't slide nicely. Especially if I went cheap on pads. Usually it's not much work to get them to slide properly.
Don't worry, after a winter the rust will get in and they won't slide. My Tundra was awful--at least once it lost front brakes due to the pads swelling so badly in that caliper--hammering out the pads is so much fun. No more 4 piston calipers for me, thank you very much.
Yes. Well, rust between the ears and the caliper. Only because I need to distinguish from rust jacking between the pad and the backing--I've had rust or other erosion in that area, and had a pad delaminate once (oh what fun, no brakes until that caliper pumped back up) (the other 3 still had lots of meat, but now I don't trust pads past 5 years).The metal backers swole so bad it got stuck? Sounds like what happened to my aunts car.
+1I've had to file on the ears of some brake pads
In this vein, the most time consuming bit of a brake job is "derusting" the landing zone for the stainless steel glide shields.
They MUST sit in their places all the way down.
The sell files specifically for this task. Posted on BITOG awhile ago by someone. I bought two sizes.Properly machined pads should not need to be filed. And that assumes the SS clips are new and the area where the SS clips fit into has been filed or sand blasted if there was rust.
Yeah I am starting to think that at least in the rust belt you can REALLY extend the service life of your brakes by literally taking them apart cleaning and lubing once a year.Yes. Well, rust between the ears and the caliper. Only because I need to distinguish from rust jacking between the pad and the backing--I've had rust or other erosion in that area, and had a pad delaminate once (oh what fun, no brakes until that caliper pumped back up) (the other 3 still had lots of meat, but now I don't trust pads past 5 years).
More recently my hybrid, which should "never" need brakes, needed brakes. I neglected to bust everything apart one spring and lube stuff up. One pad got stuck, the electric parking brake had the force to push it out, but it never floated back, so that car ate the rear pads in record time (like 60k) (we usually get 100k out of pads, and that's on non-hybrid vehicles).
The brake pads that I had to file on had pronounced ledges from stamping process that should have been knocked down at the factory usually by tumbling.I have begun seeing this more often on brake pads and on various brands the last couple years. I will file down the minimum amount needed to fit properly (equally on both sides is important) so they are not too tight or too loose. I'll then spray a coat of engine enamel paint on the sanded parts, let them dry, install and lube as normal.
Pads that I had to file one were just stamped out glued and painted no machining.Properly machined pads should not need to be filed. And that assumes the SS clips are new and the area where the SS clips fit into has been filed or sand blasted if there was rust.
It's a habit I developed with Ford rear disc brakes. If you didn't then you'd be replacing pads sooner. OE Hyundai calipers the cast iron swells where the H clip rides. Have to use a file on it every time.Yeah I am starting to think that at least in the rust belt you can REALLY extend the service life of your brakes by literally taking them apart cleaning and lubing once a year.
