My '98 Nissan Altima is approaching 46K mi. and has never had a transmission flush or drain 'n' refill ever. I'm certain this vital service is needed, as I'm notcing a slight bucking when shifting that wasn't there when I got the car some 20K miles ago.
My budget is tight as I am moving... I'll be driving the car from Alabama to Texas, making some sort of servicing all-the-more neccessary. Especially with the extreme heat and stop-and-go driving my car will be faced with in Texas. Anyway, I'm trying to come up with a solution that's not going to cost me in excess of $100. May be difficult to do since I have no jacks, so everything will be done at a shop.
The two options that I'm considering are A) complete system flush with a machine, replacing all 10qt of ATF and refilling or B) a quick drain and refill of 4qt as per my Haynes manual recommendation for 30K mi. service, and a $30 trans. oil cooler. In any event, I'm getting a trans. cooler, whether it be now or after the long haul.
In short, what I'm asking is... which option is more beneficial to my car? Also, can I even expect a full trans. flush for less than $100 at a reputable shop?
Lastly (I know this post is running long), would it be recommended to use Seafoam Trans Tune prior to only a drain and flush? Would the chemical left in the remaining 6qt of fluid be harmful, even after being diluted with 4qt of new fluid?
Thanks for any help.
