Transmission cool down time for spill 'n fill
D60
Colo
Here's a dumb question, which in this case would apply to an AB60F in a Tundra:
If a guy (mild PITA customer) drives his Tundra over thus it's at operating temp, about how long for the transmission fluid to drop under 100*F so fluid level can be accurately checked after a spill 'n fill?
I'm pretty slow in draining and filling these, so I think it would cool enough by the time I was ready to check it, but not sure.
Say ambient temp while driving and in the shop is ~80F, if one feels this is necessary information.
1 hour sounds right, if it has the same thermostat system as my lexus its around 200 degrees normally.
Probably 4-8 hours. It takes a long time for these transmissions to drop below 100F, especially if you are only doing a drain and refill.
I had a shop put a fan blowing on the trans for about an hour to get the temperature down. This was a Mercedes where you have to fill it and bring it up to a certain temp to check it. Has to be cooler than the full temp to fill it.
Finally did this. I was very skeptical of your info, and now I must apologize as you are correct!
After about three hours the trans was at 108 when I started it up again.
I quickly ran it through the gears, jumped out and by the time I got the lift up to where I could walk under it it was 135F
With this A750F I was choosing to believe the range of 115-130, so I was 5 degrees over. I quickly pulled the check plug, it basically dribbled a weak stream, and I called it good.
I HAD TO get this guy out of my shop. He's a church member and I'm working for free. If 5 degrees causes mass destruction, too bad. If he could leave it with me I could do a proper job.
Which year Tundra? If it is the 08 from your post today, the bulletin shows 99-111f:
https://top4runners.com/ja/2007/transfluid/T-SB-0129-08.pdf
