All parts arrived, lift scheduled, order of events documented and reviewed.
Rock n Roll ready
Happy Friday!
21 quarts ST Dexron VI licensed
OEM filter
OEM gasket (just in case)
Tools; extractor, dispenser, 10mm socket, inch pound torque wrench, scan tool (TFT temps for final fluid level check), plastic trim/fork set, rags, brake cleaner, gloves.
Targeting one hour for:
Rock n Roll ready
Happy Friday!
OEM filter
- pan drop and cleaning
- filter replacement
- pan install & torque set
- first fill ~6.5 quarts
- go through the gears stationary with brake on
- drive around the block
- back on the lift for fluid drop #2
- Extract fluid from the fill hole measuring 6.5 quarts
- Dispense 6.5 quarts into fill hole
- Drive around the block and repeat extract & dispense for a 3rd fluid swap.
- Lift the car with engine ON and scan tool connected to ODBII port tangling out the driver side door.
- Keep the engine running through entire level check procedure!
- Monitor scan tool with socket and wrench in hand ready to go.
- Focus on when TFT reaches 95 degrees on scan tool.
- Pull the fluid level check plug
- Let excess fluid drain out
- Install plug
- Confirm on the scan tool that TFT never went above 113 degrees before the plug was installed.
- Check for leaks
- Final torque set of 80 inch pounds on all pan bolts
- Check for leaks again!
- BoltMark all bolts/plugs
