Nick1994
$100 site donor 2024
Originally Posted By: rslifkin
Originally Posted By: Nick1994
A 4.0L Cherokee is rated to tow 5,000 pounds. A stock Cherokee weighs 3,000 pounds so with yours lifted with gear and stuff you're probably spot on with it being 3,500 pounds. Should have some room to go, and with a tow-bar and the transfercase in neutral it should tow ok.
No way in [censored]. Flat towing with no brakes like that would be a deathtrap. XJ brakes can barely stop an XJ, let alone 2 of them... And on a trailer, you'll be seriously pushing the weight limit.
I've pulled a ZJ on a trailer behind my ZJ. It's do-able, but I wouldn't recommend it, and certainly not to do regularly. And XJs are worse tow rigs. This is a job that NEEDS a full size half-ton truck (or bigger) to do it. A V8 Dakota might be enough to squeak by safely.
I pulled a 1974 Chevy Nova on a Uhaul car-hauler with my grandfather's 1996 Cherokee 4.0L 4x4. It stopped ok, not amazing but it was ok.
Plus, I'm pretty sure you can swap Grand Cherokee brakes onto an XJ? And throw a bigger master cylinder and booster on it.
