Nice bikes. I'm ashamed to show mine now. It's kinda old but I modded it earlier this year. Good enough for roads and light trail riding.
That's all you need.Nice bikes. I'm ashamed to show mine now. It's kinda old but I modded it earlier this year. Good enough for roads and light trail riding.
2.6" tires and 32T is pretty common with just an enormous range. I rarely use the lowest or highest, but that low is a real granny gear.2.125 tires? How many teeth is the front sprocket? It looks small, Bikes have moved on from my old paper route cruiser
Well dang. Just went for a local ride on some logging roads and around a couple gravel pits. There are some extreme inclines at a couple of the "hidden" trail entrances. Sometime during the ride I broke a tooth tip on the 52! Nothing violent, no hard shifts. Went into low 5-6 times. Oddly I don't notice it when riding. Not in the mood to buy a $300 cassette!50, 51 and 52 tooth largest cassette cogs (12-speed) are the current industry standard in mountain biking. The elimination of front derailleurs is one of the best advancements in mountain biking in the last decade.
I’m running a 32t oval front and 11-50t SRAM 12-speed Eagle NX setup now. I have a 10-50t Eagle GX cassette and a Roval Carbon rear wheel ready to install when my current rear wears out or breaks.
Argh!!Well dang. Just went for a local ride on some logging roads and around a couple gravel pits. There are some extreme inclines at a couple of the "hidden" trail entrances. Sometime during the ride I broke a tooth tip on the 52! Nothing violent, no hard shifts. Went into low 5-6 times. Oddly I don't notice it when riding. Not in the mood to buy a $300 cassette!
That sucks, I've heard from some riders that the "lower-end" 12spd SRAM cassettes really suck as they make em razer thin and the top cassette is made of aluminum (vs titanium is the xx-1, or what i call the $$-1)Well dang. Just went for a local ride on some logging roads and around a couple gravel pits. There are some extreme inclines at a couple of the "hidden" trail entrances. Sometime during the ride I broke a tooth tip on the 52! Nothing violent, no hard shifts. Went into low 5-6 times. Oddly I don't notice it when riding. Not in the mood to buy a $300 cassette!
The top cog is aluminum, rest of the cassette is steel (why they do this i have no idea)Pretty sure it's steel. Plan now is to clean it up and ride. Basically deburr it. Just use it up and then replace.
I may contact the bike shop for warranty but my expectations are below sea level.
Yes. I should know, 52T steel chainring is heavy. I should have researched it first................although on the SRAM website I don't see that detail anywhere I looked. I used a magnet!The top cog is aluminum, rest of the cassette is steel (why they do this i have no idea)
Honestly, bike shop will probably tell you its user error and "blah blah blah, not our problem"
My apologies, I must of mistaken xx1 as titanium (I remember a old video mentioning it, was later told wrong)Yes. I should know, 52T steel chainring is heavy. I should have researched it first................although on the SRAM website I don't see that detail anywhere I looked. I used a magnet!
When this cassette is worn to nothing, I will most likely upgrade.
What level do they move away from aluminum? Is the XG-1295 52T Titanium?
No sweat. Gonna clean the toof and ride. Will shop and replace if things get nasty, may do new chain at that point as well.My apologies, I must of mistaken xx1 as titanium (I remember a old video mentioning it, was later told wrong)
It does however have a titanium COATING
Looks like the all the 520 cassettes have a aluminum cog, just a different coating process (and slight manufacturing change as well)
I agree. 10, 11, 12 is all marketing. What matters is the ratio difference between the smallest & biggest (e.g. 10-42 = 4.2:1). Once you get 9 or 10 gears, the steps between ratios are plenty small enough that having more (like 11 or 12) is totally irrelevant. In fact, it's counterproductive as it makes the sprockets and chain thinner and less durable, and the derailleur tuning more sensitive, and the cog heavier.Yes. I should know, 52T steel chainring is heavy. I should have researched it first................although on the SRAM website I don't see that detail anywhere I looked. I used a magnet!
Reasons:The top cog is aluminum, rest of the cassette is steel (why they do this i have no idea) ...
