Originally Posted By: Drew99GT
How do you guys deal with oil filters that mount with the open side facing up? I just changed the oil on my mom's Impala, and yet again, oil splashed out everyone, all over my hand, and droplets splattered all over the garage floor! It takes half a roll of paper towels to clean the mess up.
Thanks!
I am so use to doing vertical Chevy filters that getting oil all over me is expected. There is a little trick to removing the filter. First break the filter loose until you start to see a small trickle of oil coming down the side. Move your hand off to the side and just using your midle finger and thumb to unscrew the filter. You can wiggle the filter a little to see how many threads remain holding the can to the engine. When the filter breaks free of the threads, bring the filter down fairly quickly toward you while simultaneously letting it pivot between your thumb and middle finger so the opening falls away from you. Your index finger can be used to help push the filter over in the right direction away from you. If you have an open pan, do the filter first otherwise you will get a hot oil shower when the filter plops into the oil in the pan.
I hated the horizontal filter in my Porsche. I would get about a quart of oil inside the engine compartment everytim I changed the filter. The engine compartment was sealed from the outside, so cleaning up a quart of spilled oil was a PITA. I learned to put rags under the filter to catch as much oil as possible.
