Doyall, I think that what chris and I are doing is debating opinions not arguing.
Chris, "I think you should stay clear of the "prove/proof" word until your theory has been show to be repeatable under each test scenario."
Fair enough.
There's some more I think needs to be mentioned.. Oil filtration will exceed it's ability to flow IMO(hows that), as filtration media will grow old from hot and cold oil over a period of time. Like any thing such as a sponge, the fibers will start to fray and also contribute to reducing flow. Another interesting thing I noticed is that when I took a new filter media, put oil in a can and stuck the filter media into the oil, it took a bit for the media to absorb enough oil to pass through to the middle. As it did, the outside level of oil went down. So, when I took my filter media off my engine and replaced with a straight plate eliminating the full flow filter, my oil change which normally consists of 4.25 quarts to get full, only took exactly 3quarts to fill up. There was over a qt of oil capacity in that little filter locked up in the media. No wonder the filter was much heavier when pulled off.
As for why the lead numbers are higher in a 4k drain over a 10k drain, good question. As I look at a lot of analysis, ever notice that 2k, and some 3k drains seem to have higher wear numbers than 5-6k drains? I think that there is a time where it takes a while maybe for all of the oil to pass through the filter media maybe. Of course after a while longer, the media may be going into bypass more and more then by that time, full flow is occurring quicker thus if what I'm noticing is there is less wear? until you pass a certain point where the media isn't working at all thus no filtration is working and wear numbers eventually start to accumulate. This may prove out to show when I get my analysis back without a filter. If this is the case, I'll have elevated wear numbers in 4k than any of the previous analysis. Then once I install the bypass, my wear numbers effectively should fall below any others as then I'll have full flow but also filtration.
Something I'd like you to answer, Since I used a m1 filter with a pao blend on one analysis at 4k , and then switched to a fram with a mineral counter part oil of the blend for 4k, why then would I get a lower lead count on the mineral and fram filter than a blend with the "pao" in it? Any thoughts or opinions on this? have any idea what it might prove? definitely the mineral can't be that much superior to an exact copy of the blend without pao.
